Windows 8.1 / ETS 4 installatie
intraco
Re: Windows 8.1 / ETS 4 installatie
Bericht door intraco »
egfdevos schreef:Zoek het volgende bestand eens op:
C:\Program Files\Microsoft SQL Server\100\Setup Bootstrap\Log\ Summary.txt
Daar zou je zoiets moeten zien met alles "Passed"
Code: Selecteer alles
Overall summary:
  Final result:                  Passed
  Exit code (Decimal):           0
  Exit message:                  Passed
  Start time:                    2013-11-27 06:03:22
  End time:                      2013-11-27 06:04:39
  Requested action:              Patch
Instance KNXETS4 overall summary:
  Start time:                    2013-11-27 06:03:42
  End time:                      2013-11-27 06:04:27
Overall summary:
Start time: 2014-09-21 11:37:58
End time: 2014-09-21 11:38:46
Start time: 2014-09-21 11:38:11
End time: 2014-09-21 11:38:37
Machine Properties:
Machine name: van dalen
Machine processor count: 8
OS version: Future Windows Version
OS service pack:
OS region: Nederland
OS language: Nederlands (Nederland)
OS architecture: x64
Process architecture: 64 Bit
OS clustered: No
Product features discovered:
Product Instance Instance ID Feature Language Edition Version Clustered
Sql Server 2008 R2 KNXETS4 MSSQL10_50.KNXETS4 Database Engine Services 1033 Express Edition 10.52.4000.0 No
Package properties:
Description: SQL Server Database Services 2008 R2
ProductName: SQL2008
Type: RTM
Version: 10
SPLevel: 2
KBArticle: KB2977320
KBArticleHyperlink: http://support.microsoft.com/?kbid=2977320
PatchType: GDR
AssociatedHotfixBuild: 4321
Platform: x64
PatchLevel: 10.52.4033.0
ProductVersion: 10.52.4000.0
GDRReservedRange: 10.50.1610.0:10.50.1700.0;10.50.2500.0:10.50.2699.0;10.50.4001.0:10.50.4250.0
PackageName: SQLServer2008R2-KB2977320-x64.exe
Installation location: d:\9e97f907b9650737135d8ece1047ad\x64\setup\
Updated product edition:
Instance Edition
KNXETS4 EXPRESS
User Input Settings:
ACTION: Patch
ALLINSTANCES: True
CLUSTERPASSIVE: False
CONFIGURATIONFILE:
ENU: False
FARMACCOUNT: <empty>
FARMADMINPORT: 0
FARMPASSWORD: *****
HELP: False
INDICATEPROGRESS: False
INSTANCEID: <empty>
INSTANCENAME: <empty>
PASSPHRASE: *****
QUIET: True
QUIETSIMPLE: False
UIMODE: Normal
X86: False
Rules with failures:
Global rules:
There are no scenario-specific rules.
Rules report file: C:\Program Files\Microsoft SQL Server\100\Setup Bootstrap\Log\20140921_113757\SystemConfigurationCheck_Report.htm
Dit heb ik kunnen vinden, het is een hele lijst
GeertAki
Bericht door GeertAki »
Hey Intraco, dat is wel balen zeg.
Magere troost misschien, maar ETS5 dat binnenkort uitkomt werkt zonder SQL server.
Ik hoop dat je nog een oplossing vindt voor jouw probleem en dat je die gasten van de support zo ver krijgt om actief mee te blijven zoeken of op zijn minst zo ver krijgt dat ze je een fikse korting kunnen geven op de update naar ETS5. Als je ETS4 Pro nog niet lang geleden gekocht heb, heb je recht op een gratis update dacht ik.
Volgens het log is die SQL server helemaal ok.
Dan weet ik zo ook niet waar het te moeten zoeken.
intraco
egfdevos schreef:Volgens het log is die SQL server helemaal ok.
In ieder geval bedankt voor het meedenken !!!
intraco
GeertAki schreef:Hey Intraco, dat is wel balen zeg.
Ik heb zojuist begrepen dat ETS5 1 oktober uitkomt, maar een korting kan ik wel vergeten denk ik , er werd niet op gereageerd door het support van knx Belgie, erg jammer !!!
Ik ben in ieder geval niet de enige die problemen heeft met de installatie op windows 8.1 heb ik gehoord
Ik kreeg te horen van de support dat duizenden anderen wel draaien op 8.1 alleen IK NIET.
nickv
Bericht door nickv »
Ik zou toch blijven doordrukken via support, als betalende klant zijn ze mijns inziens verplicht om je te helpen dit aan de praat te krijgen op je systeem. Te meer als ze voor ETS4 compatibiliteit claimen met Windows 8.
Maar ik weet hoe dat gaat via support met zulke 'corner cases', als de klant niet aandringt wordt er geprobeerd het probleem onder de mat te vegen :roll:
Blijf inderdaad aandringen, of - omdat je je betaalde ETS4 niet hebt kunnen gebruiken - eis een gratis update naar ETS5.
Soms wordt overeengekomen dat er echt een diepe analyse gebeurt, en als blijkt dat het probleem bij ETS ligt, is dat gratis. Als er echter zou blijken dat één of ander hoek in jouw Windows aan de oorzaak lag, moet je betalen. Maar dat kan duur uitdraaien.
Bij mij draait versie 4 zonder problemen op win 8.1
JurgenS
Bericht door JurgenS »
Een maat voor niks voor jou maar ook bij mij zonder problemen op 8.1...
vankampenp
Bericht door vankampenp »
Kijk eens in de Windows Event log of je daar iets in kan vinden. Bij mij werkt ETS4 zonder problemen (zonder compatibiliteitsmodus) op Windows 8.1
